vcProperty
Property object with its own set of properties, methods and event handlers.
Children: vcBoolListProperty, vcBoolProperty, vcButtonProperty, vcExpressionProperty, vcIntEnumProperty, vcIntLimitProperty, ... (see more)
vcBoolListProperty
vcBoolProperty
vcButtonProperty
vcIntEnumProperty
vcIntLimitProperty
vcIntListProperty
vcIntProperty
vcIntStepProperty
vcListReferenceProperty
vcMaterialProperty
vcMatrixListProperty
vcMatrixProperty
vcMatrixStepProperty
vcProxyProperty
vcRealLimitProperty
vcRealListProperty
vcRealProperty
vcRealStepProperty
vcReferenceProperty
vcStringListProperty
vcStringProperty
vcStringStepProperty
vcUriProperty
vcVectorListProperty
vcVectorProperty
vcVectorStepProperty
Referenced by: vcGetPropertyStatement.SelectedProperty, vcProcessSetPropertyStatement.ValueExpression, vcProductTypeFilter.AcceptedFlowGroupsProperty, vcProductTypeFilter.AcceptedProductTypesProperty, ... (see more)
vcPropertyConditionStatement.SelectedProperty
vcPropertyContainer.create()
vcPropertyExpressionProperty.CalculatedValue
vcProxyProperty.TargetProperty
vcRunRobotRoutineStatement.RoutineNameProperty
vcStatisticsSeries.Property
GroupIntegerRWGets or sets the group assignment of property.
Properties are ordered by groups, and a group number is automatically assigned at the time of creation. This order can be overridden to have properties come before or after one another when listed in the GUI.
IsPersistentBooleanRWGets or sets if property value is saved with component or layout.
ValueError: When changing the persistency of a built-in property.
IsVisibleBooleanRWGets or sets if the property is visible in the Properties panel.
NameStringRWGets or sets the name of property.
ValueError: When changing the name of a built-in property.
ValueError: When name is not unique inside the property container.
RebuildOnChangeBooleanRWGets or sets if component geometry is rebuilt when the property value is changed.
ValueError: When changing the component rebuild behavior of a built-in property.
ReconfigureOnChangeBooleanRWGets or sets if component structure is reconfigured when the property value is changed.
ValueError: When changing the component reconfiguration behavior of a built-in property.
UpdateOnChangeBooleanRWGets or sets if simulation world is updated when the property value is changed.
ValueError: When changing the simulation world update behavior of a built-in property.
WritableWhenConnectedBooleanRWGets or sets if property value can be set when component of property is connected to another component via interface.
ValueError: When changing the writability of a built-in property.
WritableWhenDisconnectedBooleanRWGets or sets if property value can be set when component of property is not connected to another component via interface.
WritableWhenSimulatingBooleanRWGets or sets if property value can be set when a simulation is running.
deleteNoneNoneDeletes the property.
ValueError: When deleting a built-in property.
ValueError: When the property container cannot be modified.
NameParametersDescription
OnChangedvcProperty propertyTriggered when value of property is changed.
property (vcProperty): The property that changed.
Example: Create New Property
"""This example shows how to create a property and set its value."""
import vcCore as vc
comp = vc.getComponent()
prop_container = comp.Properties
counter_prop = prop_container.create(vc.vcPropertyType.INT,"Counter")
counter_prop.Value = 10
Example: Wait for Property Value
""" This example shows how to wait for a property value to change."""
import vcCore as vc
async def OnRun():
  int_prop = comp.Properties["Integer_1"]
  await int_prop.waitFor(5, waitTrigger = True)
Example: Read Property Value
""" This example shows how to read a property value from a component."""
import vcCore as vc
counter_prop = comp.Properties["Counter"]
print (counter_prop.Value)
Example: Wait for Property Value Filter Function
if the value passes the filter function."""
import vcCore as vc
async def OnRun():
  # use the inline lambda function as filter
  await int_prop.OnChanged.wait(lambda x: x.Value > 5)
